Rob White
- May 7, 2001
I just received my 43 in. 4:3 aspect Sony rptv. I'm very concerned about burn-in during the first 100 hours. I have it on the floor in the living room until the room I'm building is ready.
I had hoped to break it in with cable, but I don't have a coaxial cable long enough to meet it. Then I wanted to break it in by watching a few dvd's I have from netflix.com but they are all widescreen format and I'm assuming that it would be a BIG mistake to use black bars during the first 100 hours. So I'm stuck with using the VCR.
I already set the contrast and brightness around 30%. Do you think I can use a widescreen dvd to break-in my tv or should I stick to the VCR or spring for a $10 longer coax cable?
Thanks in advance for your help,
Rob
Receiver: Onkyo 595
Speakers: Energy Encores
TV: TBA
DVD/CD: Panasonic RV-31
Rob
Receiver: Onkyo 595
TV: TBA
