Bryan Michael
- Mar 2, 2002
i am considering this box for my av15
Box type : Vented
Box size : 350.0 l
Tuning frequency : 16.00 Hz
Vent : 2 vent(s)
0.463 m length for each
0.102 m round
Relative
Freq Gain Phase SPL
[Hz] [dB] [deg] [dB]
5.00 -44.04 318.47 69.90
10.00 -19.12 274.71 94.82
15.00 -4.50 201. 109.44
20.00 -2.54 133. 111.40
25.00 -2.62 106.16 111.32
30.00 -2.41 90.43 111.53
35.00 -2.12 79.43 111.82
40.00 -1.83 71.01 112.11
45.00 -1.58 64.26 112.36
50.00 -1.36 58.68 112.58
55.00 -1.19 53.99 112.76
60.00 -1.04 49.9 112.91
65.00 -0.91 46.51 113.03
70.00 -0.80 43.48 113.14
75.00 -0.72 40.81 113.22
80.00 -0.64 38.44 113.30
85.00 -0.58 36.33 113.37
90.00 -0.52 34.43 113.42
do this look like a good setup?
do you think 350wats will be enough power?
i can buld the box as big as i need it will be under the stairs and not in my ht all you will see is the av 15 maybe 2 and the ports but i will have a cover for them
i moddled this in winisd beta any input would be good.
also on the box would it be ok if i just buld ribs to strethin the box instead of the piece of mdfb with holes in it. it would be kind of like one bog hole in the center and the ribs running all the way around the inside of the box
thanks
bryan
Box type : Vented
Box size : 350.0 l
Vent : 2 vent(s)
0.102 m round
Relative
Freq Gain Phase SPL
thanks
bryan
