Elphaba
- Jun 24, 2007
- Gilda
Ok, I read somewhere (and can't find it right now) that when hooking up a DVD player, surround sound receiver, and LCD tv, that there is sometimes a small problem with the audio sychronizing properly with the video due to the LCD taking some time to process the video signal.
My equipment:
TV: Philips 42PFfl7432D/37
DVD player: Panasonic DMP-BD10A
Receiver: Yamaha VS-X661
Connections: HDMI from DVD to TV; Optical Digital from DVD to reciever.
I set the surround sound parameters using the auto calibration and corrected a couple of speaker distances (the center and left rear were slightly off).
Questions:
Is this delay something I need to worry about?
How can I tell if I have it?
How do I correct it if I do? My receiver has a setting where I can adjust the initial delay from 0-99ms.
Subwoofer crossover:
I have a set of JBL SCS 500.5 speakers. The auto setup set the crossover to 200hz, and all LFE and bass to subwoofer. While talking to a friend who's into HT at church, he said that crossover was too high, and I need to bump it down to 160 or 120 to get a little smoother transition from the fronts to the sub.
Should I trust the Yamaha's auto setup, or reset the crossover?
Also, there's a choice of having the bass signal sent to the sub only or the sub and fronts. The receiver chose sub only. The guy at church said this is the correct setting for small front speakers. Is this correct?
Any feedback would be appreciated.
Gilda
My equipment:
Questions:
Gilda
