Mike Up
- Dec 16, 2002
Edward,
Calibrate all your speakers except the sub to Reference Level 75 dB with the internal test tones. Then run the test tone for the sub and set the sub level to -10 and then adjust the plate amp so the SPL meter reads 75 dB. Run a speaker-sub sweep with AVIA for each surround channel and then for the LFE channel only. Note the results.I have done just that in my setup previously. I ran ovations sweep with my S&V disc. It's the same, S&Vs disc is a toned down version AVIA. I had very strong bass with the sweep in using DD.
I have a disc that has the subwoofer signals mixed in the front channels. So that when the speakers are set to small, the bass signals are sent to the subwoofer output. I calibrated all speakers, including the subwoofer to 75db. I then have Video Essentials where their test signals are all in 5.1 where the sub signal is the .1 channel. It matched perfectly. Since I was trying to get the best bass, I was experimenting for about a week with placement, as I said in the earlier message. I always referenced the LFE .1 signal against the directed bass. No matter which level the receiver's subwoofer level was at, they always matched. Also, I adjusted my subwoofer's internal amplifier at different times. I guess your calling the subwoofer's internal amp the plate amp? So last month, I essentially did everything your doing and I had no problems.
I think I know what your problem 'could' be. I had several problems in room location with my sub. I had cancellations and boosting all at different frequencies. The reason was directly related to the crossovers. "THE LFE CHANNEL WAS NOT AFFECTED!"
With a poorly placed sub that's suffering from cancellations or boosting related to timing errors with the main speakers, you'll have bass problems related to bass that was directed from small speakers, but the LFE channel bass will be unaffected since it's not affected by timing errors and reflections.
I suggest you move you subwoofer and try different placements. My AVR-3803 doesn't suffer this but that's because I tuned my sub placement to my room. The more I read your comments, the more I think this is your problem.
Good luck.
