- Jul 19, 2002
I'm looking for a 5ch amp in the sub-$400 range and while browsing on ebay I came across the Legacy LUM-A1 5ch amp. It says it's the same as a Proton AA-2580.
On further research (google) it seems the AA-2580 is the 5ch amp made to go w/ the AA-2631 DD/DTS pre-amp (which evidently won an award at the 2000 CES). I've also found some very positive reviews on www.audioreview.com but i usually take those with a grain of salt.
Now... has anyone heard of or used either of these brands/amps? I'm assuming it's not the same Legacy known for EXTREME low end car-audio... and i'm also assuming it's not the same Legacy know for EXTREME high end music speakers... but it could be either. Either way, the amp seems to be going for less than $200 on ebay, and I'm wondering if it's a steal or junk.
The only other amp i've been able to find in the price range is the HK PA5800 which i've read some very good reviews on. I'll be using a Pioneer Elite 43TX as a pre-pro. I wouldn't be considering an amp if the 43TX could handle 4ohm loads. I'm hoping to upgrade to Swan Divas soon, but it looks like i'll need an external amp before that happens.
Any info would be helpful. Thanks
