Lanny M
- Dec 3, 1998
I'm considering adding the side surrounds to my current setup, but I have a placement problem. The entire right side of my listening position is open to the kitchen area.
I'm currently running 5.1, with the rears consisting of Paradigm Ref in-wall speakers mounted about 7 feet behind the listening position. My options for the side surround appear to be mounting another set of in-walls either in front or behind the listening position, or possibly trying the Paradigm Ref ADPs, a di-pole wall mount speaker. If I mount behind, the speakers will be located within 3 feet of the rears and about 3 feet behind the listening position. If I mount in front, the speakers will be about 6 feet in front of the listening position.
Does anyone have any experience with placements similar to this?
