Keith Townsend
- Mar 5, 2002
I'm debating between getting a 36" traditional TV and a 36" Flat non HDTV. I have about a $1000 budget excluding tax and extra's for my TV. I'm putting it in my Family room which is 11.5x18. The viewing distance is about 15 Feet. I love the image that a flat screen gives in the store and the 36" traditional isn't bad. I use my TV for mainly wacthing DVD's and a little cable. I like the advantages of 16:9 on a flat "32 inch but I believe the viewing distance may be to great for this size TV. So I'm looking into 36" traditionals. The last TV I brought was my current 27" traditional 6 years ago. More than likely it will be another 6 years before I buy another TV. Any suggestions would be appreciated.
Keith
Keith
