Jay H
Soon to be a new home owner and I know I'm going to need tools so I casually look at the various hardware ads, online and off.. Can anybody recommend a decent say starter set? I know I'll need a drill and circular saw, not sure if I'll need a recip. saw but hey, some of those 4 tool kits aren't terribly expensive.
I also saw some reconditioned ones online, are they reliable, should I worry about them?
Lowes has this really cheapo brand called Firesafe or something like that, but they have a 4 brand thing for $129 or so but they also have a Hitashi seemingly midprice 4 piece combo for $269 or so. that would be somewhat halfway between the cheap Firesafe and the expensive DeWalts...
As far as my intended use, I plan on making a bunch of bike holders in my basement using 2x4s and dowels so I'll need a drill and stuff to drill out holes and i will be making a kayak carrier on the floor joists (so I can slide my kayak in and out through the basement window...) Anyway, nothing major at least yet...
Jay
Jay
