Justin Gates
- Feb 26, 2001
I'm using WinDVD and I have hypersnap-dx. I want to be able to make some screen captures of DVDs. I've found the best way in hypsersnap is to just use the Print Screen button because it only captures the image and not the surrounding window. The only problem I'm having is on anamorphic discs the screen capture is not at the correct aspect. The resulting image looks like a anamophic image that is "unsqueezed", every thing is tall and narrow.
What am I missing or doing wrong?
Here is an example, this image should be 2.35:1, it is from resident evil:
