DTS-HD Master Audio 24-bits/96Kz vs Dolby True HD 24-bits/96kz (1 Viewer)
Dobson
Roger Strutton
Hi,
Should there be a difference when comparing (listening) to both?
Dobson
Dobson
Roger Strutton
"Pure Audio" has Blu-ray audio releases that include both. I have a Rolling Stones "GRRR" and Bob Marleys "Legend".
These are in stereo. There is also a PCM option as well.
Between the DTS and Dolby I can't hear that much difference.
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Now that you've cleared up your talking about Pure Audio...Every review of Grrr I've seen says there is no difference between the three lossless tracks.Legend, nobody has done a listening test.But, like I've regurgitated numerous times before...The core audio of Dolby True HD is MLP.where did MLP exist before?DVD-A.DVD-A=Dolby True HD
SoundSolutions5
Canada
Home Theater
DTS-HD High Resolution Audio can be used as the sole audio codec, ensuring highest audio quality for HDMI enabled devices and backwards compatibility with legacy devices at up to 1509 kbps.
Nielmb
