mrcp77
- Aug 19, 2009
- Michael
The Facts: I have a Bose V20 system that uses bare speaker wire to connect to the speakers but the other end of the wire has a male RCA plugs that goes into the subwoofer for each of the 5 channels. My home is prewired with speaker wires for the 2 front and 2 rear speakers and they have bare speaker wires on both ends, these speaker wires all terminate at the central location where I have my components. The builder did not install any wall/speaker plates, these are literally speaker wires hanging our of a hole in the wall. The Questions: What is the best way to connect my subwoofer (which requires male RCA plugs) and the pre-wiring (which are bare wires)? Can I find an RCA plug adapter that I can just solder or attach the bare wires to? Should I just twist the Bose bare wire ends onto the pre-wire bare ends and cap them? What do I need to do the best job? Thanks!
