Subwoofer doesn't work...?? (1 Viewer)
$L1ckr4y
Raymond
So thank God, I finally received my subwoofer last night. It was the proudest moment of my life :P . However, after hooking it up with my yamaha RX-V595a receiver, I can't get any NO sound out of my subwoofer. I hooked them up properly, I activate the subwoofer channel on my subwoofer, turned it up the volume level to 5, and the power light on subwoofer lit up. FYI: i have BIC active subwoofer 12". One thing that i'm not sure though, since I was lazy to go to Radioshack to get some RCA subwoofer cable, I used the regular RCA cable ....like the red and white ones. Is there a difference between RCA subwoofer cable and RCA audio (red and white) cable....??? I'm sorry guys, i'm a total newbie when it comes to this home theatre stuff. PLease help, I really want to get my subwoofer started :D.
troy evans
Did you go into the Yamaha receivers menu and select the subwoofer "Yes" setting in speaker settings section?
$L1ckr4y
Raymond
nvm guys, but thanks anyways i found out what was wrong with it. lets just i'm a dumb idiot by not turning the power ON :laugh: ....
papill6n
