Final Cut Pro and DVD Transfers (1 Viewer)
MatthewA
BANNED
Salinas, CA
Matthew
I'm working on a project using FCP that involves taking clips from DVDs and editing them together as a present for a friend (these are home videos that I already transferred to DVD), but I am having probelms with the interlacing. When I put the stuff back onto a DVD I get weird flickering problems on my TV.
What do I do to import 29.97 fps video from a DVD and not get the flickering?
Don Solosan
By now I expect you've found a solution, or found your way to the Apple discussions site. That's the best place to ask technical questions like this.
MatthewA
BANNED
Salinas, CA
Matthew
I have. I now know that I must set the field order to either top or bottom or it goes wonky.
But thanks for your concern.
Areles
