Audio Transparent Screen material (1 Viewer)
Marc Pasc
Theres a guy in Florida that been researching screen material since all the commercial stuff left him unimpressed with its dimness along with high cost.
Read the first paragraph and then skip to like page 45 to see the screenshots against dazian and others. I have a piece and the stuff is amazing, I am scraping a 14' Stewart Studiotek130 2.35:1 Screen for it. It seems 1 guy had troubles with moire using a Ruby PJ that he couldnt get rid of by hanging it on a slight angle
http://www.avsforum.com/avs-vb/showt...5&page=1&pp=30
Adam Gregorich
What to watch tonight?
The Other Washington
Adam
That moire problem cleared up as he had the fabric running the wrong way. The initial orders are gone, but I mhave my name on the list for any follow up buys. Were you able to get a screen in the first buy?
Marc Pasc
Yes I actually got a piece directly from the factory as part of a 3 chipper DLP with a large 14' screen test. Ruben wanted results from different groups of projectors so he sent out some early test screens for feedback
Nielmb
