Need help on projector options (1 Viewer)
James Grasso
What is out there that has a brightness of at least 1000 lumens that is under about $1800? I've been given the budget and it is to be used in a room that will have a fair amount of ambient lighting. I just need some options on what may be out there if anything. Thanks.
Nielmb
