Volume Knob Problem (1 Viewer)
eric frantz
The volume knob on my Sony DE 935 has been sticking for some time now and seems to be getting worse. When it sticks, I can turn it manually a few times and the remote will work again. has anyone had a similar problem? and if so is there an easy way to resolve it? The unit is not under warranty.
MarkO
I had the same problen with My Yamaha RXV995. I had the feeling there was a belt or some sort of small cable that drove the volume knob that was slipping. I never took it apart to find out tho. All I had to do was move it manualy a bit and it worked again for a few weeks.
Bobpaul
Hi:
Had the same problem on Sony STR-V555ES. The motor slowly started burning coils until it burnt out. I replaced it with a transplant from a toy and now it works. Having a 10 dollar Radio Shack multimeter really helped.
Ciao
Nielmb
