Greg Yeatts
- Feb 26, 2002
Any of you guys use a handheld power planer. I need to plane a bit and am considering purchasing a hend held power planer.
In a related question, is it possible for MDF to shrink or expand with humidity? I cut a panel for my enclosure, then used a router with a straight-cut bit to make 8 duplicate panels for the back and braces. I checked each of these at the time I cut them and they were perfect duplicates. I moved four of the braces into the house for a week (the rest of the panels in the garage). The panels in the house are now about 3/32 shorter than the panels I left in the garage. Could this be mdf shrinkage from lower moisture levels in my house? If so, can I just keep all of the panels in the same place for a while and hope for equalization?
TIA
TIA
