SteveCallas
- Dec 23, 2003
So now 36" length with a 188hz first port resonance IS ok? I see how it works.
Bud, if you do go ported, which I would recommend you do, use all of the available space, no need or want to decrease it at all. I'd also go with two 8" diameter ports, but I'd tune a bit higher, ~13hz with the ports being 30" in length. Sonotube would probably be the best choice of matrial to use for these ports considering the size. You'd want to add a 3/4" or larger roundover to outer layer of (MDF?) to act as a semi flare.....what are you building this out of by the way, I think I missed that. You'll also want to make the baffles - the walls the drivers are attached to - a few inches thick.
Aside from the obvious advantages of greater output and less distortion by going ported, the resulting natural FR will mesh extremely well with typical room gain, and you will likely need minimal EQ, if any at all. I can show you some real world examples of this if you like.
