I have a windows 7 pc that I have been using for working at home during this time. I saw that I could upgrade to windows 10 for free. I am most concerned about the security patches Im missing keeping Windows 7. The computer works fine otherwise. These are the Microsoft recommendation for minimums.
This is what I have.
Dell Vostro 3450
Windows 7 Professional
Intel core i3-2350M CPU @ 2.30GHZ
RAM 4GB
64 Bit Operating system
278GB Hard drive
Am I going to be able to do this and it work ok? Im thinking that I will start from scratch with Windows 10 if yall think it will work.
Thanks!
Check Windows 10 System Requirements & Specs | Microsoft
Get system requirements, specifications & important details about Windows 10 OS. Also, learn about deprecations, upgrade editions & localization languages.
www.microsoft.com
Processor: | 1 gigahertz (GHz) or faster compatible processor or System on a Chip (SoC) |
RAM: | 1 gigabyte (GB) for 32-bit or 2 GB for 64-bit |
Hard drive size: | 32GB or larger hard disk Note: See below under “More information on hard drive space to install or update Windows 10” for more details. |
Graphics card: | Compatible with DirectX 9 or later with WDDM 1.0 driver |
Display: | 800x600 |
Dell Vostro 3450
RAM 4GB
278GB Hard drive
Thanks!
