jlondon75
Grip
- Jan 4, 2012
- Joshua London
Hey Folks,
It has been a long while since my last foray into building PCs, so I'm simply out of touch with options... I'm now needing to replace an ancient PC (circa 2004 big-box-store; the last time I bought rather than built one) that just died. I was using it simply as a way to access my Plex Server -- and to play streaming content from YoutTube, Netflix, Amazon Prime; and also to play exactly one very low-tech game -- on an old TV (circa 2007). I’ve not had to think about this setup for about 5 years now, so I’m way behind on options. This old PC was really NOTHING MORE THAN an access point to the internet for my otherwise non-smart tv, and to play that one low-tech game.
My tv has the following open inputs available: HDMI, RGB (I was using this with my old PC), “Component”, and AV.
The "minimum requirements for my one low-tech game (a dance/exercise game that my wife loves) are the following:
- Windows XP/Vista/7/8/8.1/10 [I was given to understand that Windows 10 can be loaded onto Raspberry Pi 3 Model B+].
-2 MB RAM (4 GB+ is recommended if you want all background movies to load successfully)
-2 GB free disk space
-1.66 Ghz or above processor
-Video card that supports High Color (16-bit color) and has 64MB video RAM (128 or more is best) and OpenGL or Direct3D drivers
-DirectX 8.0 (or above) compatible sound card with drivers
In terms of a replacement/new build, I am Ideally looking to spend up to about $500 -- but cheaper is DEFINITELY better. So, any thoughts on how best to proceed?
I was kind of leaning towards maybe a “single board computer” route, like a Raspberry Pi, or an ODROID base, or a Tinker Board, but I'm not entirely certain I can easily make those work. I also started looking at the Intel NUC and the like...but I am totally open to ideas and suggestions.
What do folks here think? I'm all ears.
