What's the aspect ratio on the current "CLOCKWORK ORANGE" dvd? (1 Viewer)
Casey Neutron
I have the laserdisc and the first dvd release of this film. Both versions are letterboxed at around 1.55:1. IFC has been showing "A CLOCKWORK ORANGE" lately and it's a slightly wider version, somewhere around 1.66:1, with a little more picture information at the sides than the laser and dvd versions I have. Is the re-released "CLOCKWORK ORANGE" dvd in the same aspect ratio as the IFC version
or is it just like the others? If the newer dvd is truly 1.66:1 it would merit an instant re-buy.
Rain
Rain
I'm pretty sure the newest DVD is 1.66:1 or very close.
Jon Sheedy
I don't EVEN want to use the words Kubrick and aspect ratio in the same sentence! ;) But I will say that the remastered Clockwork dvd is a considerable improvement, picture and soundwise, over the previous release...more than enough to merit a re-buy in itself, imo.
JoN
Mark_vdH
Which version are you guys talking about? The 2000 re-master DVD with 5.1? Or the 2 disc one, which I know nothing about?
The 2 disc edition has exactly the same movie disc as the remastered edition. The second disc contains the original soundtrack on a CD.
Ken_McAlinden
Livonia, MI USA
Kenneth McAlinden
I used a cursor to measure the latest R1 DVD[geek alarms blaring all over the forum], and it was 1.66:1 almost on the dot, as was Lolita. IIRC, Barry Lyndon was something like 1.54:1.
Bill Leber
How can you tell the difference between the original DVD and the remaster? Is the cover different, or should I check the aspect ratio on the back of the box? A Clockwork Orange is on top of my list of favorite movies I don't own the DVD of because I heard it was a lousy disc. I didn't even know they re-released it.
ChuckDeLa
The remaster will say "DIGITALLY RESTORED AND REMASTERED" across the front under the words "STANLEY KUBRICK COLLECTION".
DaViD Boulet
Yet another 1.66:1 WB title that's not 16x9 encoded (which adds resolution for 1.66:1 titles vs 4x3 encoding)
grrr.
Kevin M
Kevin Ray
It wouldn't have been a huge leap to make it 16:9 enhanced but they still would have had to cut a small bit of the proper framing to accomplish it, right?
They could have window-boxed it I suppose.
Damin J Toell
Brooklyn, NY
Damin J. Toell
Nothing would have to be cropped. 1.66:1 anamorphic has black bars on the sides of the image, as you suggest.
DJ
Ken_McAlinden
Livonia, MI USA
Kenneth McAlinden
The trade-off with 16:9 enhancement and windowboxing of 1.66:1 films is pretty slight for 4:3 TV viewers. It starts to become more severe when you are dealing with aspect ratios less than 1.60:1, though.
Mark_vdH
Why can't a full 1:33 AR be anamorphic?
What's the point?
You would be losing resolution.
[Edit] It theoretically can be 4:3 anamorphic though, and Anchor Bay tends to this with 4:3 behind the scenes documantaries (and stuff like that). The thought behind this seems to me that (widescreen) movieclips that are in these documentaries can be shown "properly" on 16:9 sets this way, instead of looking window-boxed.
Sorry, can't really explain it properly in English :)
Nielmb
