What Denon model should be similar to AVR-3808CI in today's market? (1 Viewer)
orestes
Orestes
I don't want to upgrade now, but I will be moving from CA to NC some time this year. I just want to know if my AVR-3808CI gets ruined or damaged on transit, what will be the model to replace it? Thanks.
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Right now...believe it or not...the 3808 is "still current"....blame... 1. The earthquake/tsunami 2. Denon giving up "mid high-end" to Onkyo/Integra (once you hit $1000, Denon/Marantz is irrelevant...at the moment) 3. The current "market death" in the $1500/$2500 range...(Elite and Yamaha have retreated "cheaper" as well. Add Marantz as "nothing more than a Denon in a dress"...meant figuratively and literally) Help is on the way in the 4520(whenever it is released in the US)
schan1269
HTF Expert
Sam
Oh yeah...there is the 4310/4311. Neither of which is anywhere(realistically) near the 3808. The 3808 has a near 1 AMP advantage in how much it pulls off the wall compared to the 4310/11. Edit: The 4310 pulls 8.2 amp(close to 1000 watts) The 3808 pulls 864. The 4311 pulls 780 watts. So, unless you need 1.4...wait for the 4520.
orestes
Orestes
While looking on the Internet for my current model 3808CI, I was not able to find an online retailer with such a model; and thus, I thought if mine gets damaged during transit, I will need to replace it with a similar model. So Where do I go to buy a replacement? Thanks for your comments.
orestes
Orestes
Thank you. I guess for what you said that the 3808CI is better than either the 4310 and/or 4311. Then, I hope my receiver does not get damaged on transit so that I can still use it.
orestes
Orestes
How about the 3313CI to replace my current receiver in case it gets damaged? Thanks.
gene c
Bay area, Ca
Gene
I would think the 3312/3313 would be close enough. Amp sections have generally been down-graded as more and more features are added with pricing remaining about the same.
schan1269
HTF Expert
Sam
Which is why I said wait for the 4520. The 38/4308 are Monsters of the Midway, the 4310/11 are merely sideshows...
gene c
Bay area, Ca
Gene
This is just a 'what if' senario and I'm sure the 4520 will be a Monster of the Midway, but if his 3808 is damaged I think the 4311 would be an adequate replacement, and unless he really does need a beefy amp section then I bet he would be fairly happy with the 3313 in it's place. Remember, most people buy way more receiver then they actually need. But of course, it's his decision.
orestes
Orestes
So it seems that if my 3808CI gets damaged, then I should wait for the 4520. Is this a 4520CI model? By the way, I will only need to replace my 3808CI if and only if it get damaged on transit, but I will do my best to pack it on its original box and then on a bigger box to minimize damage by cradling it with some other stuff like pillows and blankets. Anyhow, thanks for your comments.
orestes
Orestes
I totally agree with replacing it with 3313CI if and only if I am so unlucky to get my current model damaged. Thanks.
annefnlys01
