Anyone using something like an Atomos Ninja V for videos w/ their mirrorless (or DSLR?) cams? What's your preferred choice and why, if not the Ninja V?
As I mentioned elsewhere, I'm likely (and previously unexpectedly) picking up a Nikon Z6 kit later today... but want to make more sure about the video side of things since that's a major factor in going mirrorless at all.
I usually expect to shoot videos on a tripod... at least w/ such a rig anyway (even though I often deferred to a small Panny 1080p camcorder handheld w/ a monopod-plus-attached-Tascam-recorder wedged against my body)...
The Atomos solutions concern me a bit when it comes to fan noise (and heat perhaps). I guess I will probably need to place the monitor as far as possible away from my Tascam recorder (or whatever mic) -- I used to just attach the recorder to the tripod ~1/2ft below the camera... but not sure that's good enough anymore.
Ideally, I'd set up stereo miking much closer to subjects for best sound, but that's a bit extreme and not usually possible for the kids' recitals (unless I was the official shooter providing near-pro resuls, LOL), which are what I shoot most on video. I don't really even need 4K video for that... though better codecs in the Atomos, et al along w/ recording to SSD is desired... and the Z6 apparently isn't good for external miking anyway (due to noisy preamp). I do have a Rode shotgun mic, but that's no good for stereo sound -- and the Rode stereo mic might not be noticeably better than my Tascam recorder (and can't backup the audio).
Think I might need to set up the monitor on a separate arm running off the tripod's video head (Manfrotto Nitrotech N8).
Anyone here done that w/ something like the Ninja V? Any better choices/suggestions in similar ballpark?
Guess I'll probably need to use post-NR to filter out the fan noise along w/ other ambient noise that I already usually do (merely a passable job w/ Audacity)... Just wish I could minimize the noise so less/simpler NR is needed -- also, probably have to hope the fan noise doesn't vary mid-recording to keep things simpler.
I did find a Vimeo video demonstrating the noise diff between the Ninja V and the bigger Ninja (and Shogun?) Inferno. Wonder which is easier to filter out particularly for violin music -- I'm guessing the lower frequency noise of the Inferno... but the Inferno is otherwise probably overkill, including the necessary complete kit costs, especially since I'm not using pro level audio setup, eg. no XLR, no phantom power needs...
All this... and I also gotta wonder if the fan noise will be too loud for most of the recitals (not just my recording) in general... Guess I better ask to have a listen in person for myself at B&H...
Problem is I most likely need some kind of external solution and not just rely on in-camera monitoring and recording... or the Z6 won't end up being nearly as useful/good upgrade over my current setup/solution to justify the purchase...
Decisions, decisions, decisions...
_Man_
PS: Sorry about the redundant post in the mirrorless thread. Just realized I should probably break this out into its own thread since some might use a Ninja V or similar w/ a DSLR instead of mirrorless cam...
_Man_
