Jassen M. West
- Jun 22, 2000
The place I work at just bought a new printer. The problem is the printer has a usb connection and the PC that its going to connect to has Windows NT installed. The PC does have usb ports in the back but microsoft chose not to support usb in windows NT.
The printer does have a network connection so I am going to try using a hub and instead of having the printer run on the network through the pc have the printer run on the network by itself. It would be much easier if one of two options was possible. One- a cable that is USB to Parallel (the parallel has to connect to the back of the pc. Two - Make USB work in Windows NT (without paying $40 to B-Square or Jungo as I feel USB should have been supported in NT) $40 isn't much I know but we are going to do a whole office upgrade a little later this year so the cheaper the better.
Any help would be appreciated.
