JeffSC
- Sep 16, 2004
I am building a new house and my wife has agreed that the TV in our family room would be most conducive to furniture placement if it were hung over the fireplace... lucky me! So, needless to say, it will have to be flat screen... but I have a few questions I am hoping someone can shed some light on for me...
1) I am a little unsure about the height of the TV in relation to the furniture and viewing angle... the TV bottom would be about 6' above the floor. For those of you who have your flat screen mounted high like that, do you prefer it over eye level, or not? I assume the mounting bracket has an adjustable angle to keep it angled toward the viewing areas?
2) Can anyone point me to a flat panel mounting bracket spec sheet? I am trying to understand what kind of blocking I should put in the fireplace wall before the drywall goes up to make the mounting as easy and sturdy as possible.
3) Is there any concern with moutning any type of flat panel above a sealed combustion, gas fireplace? There are heat vents from the hearth into the room... would the heat source below be of concern to any type of TV mounted above?
4) If the TV will be mounted over the FP with the top angled toward the viewer, is there any thing that can be done to make the whole over fireplace area more attractive from the side view? Instead of looking at a tilted out screen and the wiring behind it?
Any advice would be greatly appreciated!
Jeff
Jeff
