Suround Speaker Advice? (1 Viewer)
Chris KAudio
Athena F2's Floor Front Speakers
Athena AS-C1 Center Channel
Most likely Harman 230 for receiver.
I have an old pair of bose speakers (cube), abou 8 years old... I could use these but feel like I shouldn't for some reason...
Any help is appreciated.
-Chris
ScottCHI
well, if you like your athenas, then an obvious choice would be one of their bookshelf speakers.
Adam.Heckman
2nd that. I have the Athena B2s for my mains, sounds like the B2 or B1 speakers could be right up your alley. OR... Athena is coming out with 'surround' speakers. Check their website. They are the 'R' speakers.
Take it easy.
kevin-van
If you looking to wall mount them, the new ASR1 works good. otherwise you can use a pair of ASB1 which is also cheaper.
papill6n
