Artyfly
- Sep 10, 2011
- Adam
So, I decided after listening to several kinds of Dalis, Magnepans, ProAc, Paradigms, that I should go with Dali & Paradigm. I bought a pair of Lektor 1 for the fronts and a Paradigm PDR-80 sub. And, I'm planning on purchasing a pair of Paradigm Atoms for the sides and a less expensive paradigm pair of satellites for the rear in a 7.1 setup in a 20(L) x 12(W) x 8(H) approximate room. I say approx since there's a nook on the side of the front part of the room and a hallway to the side in the back. So, based on what I wanted - accurate, precise sound for the best bang for the buck while still being non-Chinese made speakers, the speaker salesman recommended the Dali for the fronts and the rest as Paradigm since I didn't want to spend a ton. He doesn't actually work on a commission so I'm assuming he's not trying to steer me wrong. I mean, I understand he wants his bosses business to survive, but he's not out to make himself more mula off my purchases. The estimated budget I have is around $1500 to $2000 including an AVR, but that can be adjusted higher if needed. I basically really want the most bang for the buck all the while the speakers are non-Chinese. I guess it might be ok if they are made in China as long as they are Designed & Engineered not in China - I think the Lektors might actually be assembled in China (since they say on the back of the speakers "Designed & Engineered in Denmark". Am I correct on that? So, would any of you say this set up doesn't make sense? I've read on forums that a HT setup should have speakers from the same company & same series and that the sub can be a different company if wanted to. Also, what would be an appropriate AVR for this? I want to get a 3D capable AVR. I was looking at the Yamaha 867, but not sure if that's 3D capable. I have an Onkyo 606, which the salesman said it would be fine if I felt that it was fine. But I'm not getting the same sound quality out of the Dali fronts as the sales floor, I even bought the recommended speaker cables - Kimber Kable Kwik 16 for the fronts - that's gonna be spendy if I want that quality wire for the rest of the speakers (at $1.35 per foot - bought 30 foot so far) but I'll do it if that's the speaker wire to make quality speakers give their full potential sound quality - I know there's even better Kimber Kable 4PR and 8PR etc.. but seems those are really pricey per foot. Any advice on what exactly would be a better set up if I really want good clarity of voices/music in movies/games and the best bang for the buck for it - maybe a different Dali series or different Paradigm speakers? But the PDR 80 is awesome BTW. I know that I might not be able to afford a non-Chinese made AVR, but any suggestions on any type of AVR or even just an audio receiver is appreciated. This might be a lot to ask. But I appreciate any help. Thank you.
