David Norman
Odd dilemma and I've not sure what options are available.
High 80 yo, out of state Father in Law just moved into an Assisted Living style apartment. He basically only watches (listens) to the local TV networks -- mostly news and weather with an occasional sporting event if the local team is televised. At home he's had cable or lowest level DirecTV bundled with his phone/internet service just b/c it was easy.
I would say try to get an OTA antenna, but towers are at least 60-80+ miles away no matter which city you aim at. Years before he got cable and predigital OTA days, they had a rather large rooftop antenna with rotor which could get stations from at least 3 metro areas, but depending on weather and tree situation that really was never 100% reliable and more than once I remember being down to a single fuzzy channel as late as 1988.
Now, his apartment (no balcony) it's unlikely to be able to install and outdoor antenna and at the distances I'm sceptical of the functioning of an indoor antenna especially given my experience with the digital channels not seeming to have the legs of the old analog stations. I'm probably going to try it just to see how it works. I think his 32 in Samsung has a compatible tuner, but I'm not even 100% sure of that.
The complex has Comcast where they can get basic SD cable for $25/month which is ugly, but at least usable and with even HD is mostly lost due to at best mediocre vision. I think the cable is one-size fits all for all the residents since it seems to run like a hotel system for the couple hundred apartment. The $25 really isn't a problem, but if I can get better quality for less, I'm in.
Long preamble -- short question:
If the indoor OTA antenna option fails, Is there a streaming option that basically just supplies local networks for a small fee per month -- a lifeline type service. I need simple and something usable at least similar to channel channels on cable or a TV Tuner. Hulu or YouTube +Live seems to be overkill and over twice what he's already paying. Sling's even worse since it relies on an antenna anyway. DVR service isn't necessary and any sort of Internet interface would likely be far too cumbersome -- Turn TV on, change channel, watch.
