static look on bright colors (1 Viewer)
chad k
I have a hitachi 46f500 on certain scenes of movies on HD feeds through my cable or OTA receiver i see what looks like fine white static specs. this only happens when there is really bright colors and its moving fast (the picture) not real noticable but i notice it. anyone know what this is? And what adjustments might correct this? i adjusted my picture with AVIA when the set was a few weeks old, it is now 3-4 months old.
I dont really notice it on dvd's or the 360 so far.
Chad K
John S
That is a tough one from the description.
How are you connecting? I'd try a different HD connection and see if it is better. Like DVI/HDMI if your using Component Video or visa versa if your using DVI/HDMI try the Component Connection.
Compression of the video signal at the source can sort of cause this as well.
Paul Anthony
Chad, I have this problem too. I just bought me a Hitachi 42HDS52 plasma a couple of days ago, and have noticed major motion artifacts. I tried the Auto Movie Mode (3:2 PULLDOWN DETECTION) to eliminate the problem, but it doesn't do any good. I google searched and read that you should connect a DVI/HDMI cable through your HD feed. I haven't done this yet, because I have regular Comcast cable at the moment, and I also just ordered a DVD digital player in hopes to get rid of the motion sickness that's plaguing my HDTV.:frowning:
If all else fails, I'm going to return the Hitachi for a smaller Panasonic plasma.
chad k
Thanks, is that what i am seeing? artifacts. Its a fine grainy look to fast bright colors, i dont think anyone else can see it or notice but i do, i dont notice it when i play a dvd through component, and yes, my cable and ota box is hooked up through component, it is also being split by yamaha receiver, i will try other things to see what i can come up with.
foster2292
