Mike Butler
Grip
- Mar 28, 2002
After 3 years in a new house, I am finally setting up my TV/entertainment area. I have a Mitsubishi 50" RPTV that we bought when we moved in. I am buying an amp and speakers to go with it.
The room is our family room and has some severe limitations. It is 16X19 and two stories high that is open to the upstairs hallway. On one end of the room there is a 2 story fireplace with 2 story windows next to it and around the corner on both sides. The opposite corner is a neat angled wall that currently houses the TV perfectly. On either side there are large openings that lead to the kitchen and hallways. This is likely where the TV will stay.
I have questions about where to place the speakers. I can place the fronts right next to the set, but I have always thought they should be further spread out. Is this right? The other option is above the openings to the other rooms, but they would be 8 feet up that way. If the speakers were pointed downward, would this be ok? The red ink in the picture shows the possible locations.
The center seems logically placed on top of the TV.
The rears are also a problem. Behind the couch is the wall and behind my recliner are windows. I could mount them high up in brackets and aim them straight down, but they would end up directly overhead, not behind at all. Would this work alright?
Any other ideas based on this crude drawing I whipped up on my laptop using MS Paint during my vacation?
MIKELink Removed Link Removed
