ShawnMEC
- Jun 27, 2001
Sirs,
I need some advice.
My wife and i are finishing the basement and she's graciously agreed to allow me to build in an HT. The HT room will be ~15.5 x 22 with a kitchenette/bar covering the back wall and extending about 2 feet from it (so the room has about 15.5 x 20 for speaker placement). Ceilings are 8 with a 1 foot beam cutting the room widthwise. The viewing area starts about 10 feet from the screen.
I'm going to start doing the speaker and other low-voltage wiring soon and here's my current plan:
Front Wall:
- right main 14 inches from right wall
- left main 14 inches from left wall
- center ~12 inches from ceiling on swivel
- sub just above base trim
- center spooled and left in wall in case i decide
to get an acoustically transparent screen someday
Right Wall (all on wall-mount swivels):
- surround at ~4 feet from front wall
- surround at ~9 feet from front wall
- surround at ~14 feet from front wall
- surround at ~18 feet from front wall
(needs to leave room for cabinet doors to open
Left Wall:
mirrors right wall
Rear Wall (ceiling-mount swivels):
- rear at ~4 feet from right wall and 2 feet from
cabinets
- rear at ~4 feet from left wall and 2 feet from
cabinets
Ceiling:
- LCD projector mount at ~13 feet from front wall
(this will be a PVC conduit, power, and some extra
supports between the floor joists)
I'm planning to use this wire:
http://www.partsexpress.com/pe/showd...=2899&CATID=56
So, please hit me with any comments or suggestions! I'm still a novice so feel free to say, "You're out of your gourd! You *never* put rears off the rear wall!", or whatever.
Thanks!!
Shawn
I need some advice.
Front Wall:
Left Wall:
mirrors right wall
cabinets
cabinets
Ceiling:
Thanks!!
Shawn
