KeithH
- Mar 28, 2000
Crutchfield put the Sony STR-DA2ES receiver up on its web site overnight. It is in stock for $700. From Crutchfield's web site, here are the key features:
* dual 32-bit processors for surround decoding (Dolby Digital EX, DTS-ES, Pro Logic II, DTS 96/24), DTS Neo:6 and DCS modes
* 100 watts x 6 into 8 ohms (20-20,000 Hz) at 0.09% THD
* 5.1 and 6.1-channel inputs
* 6.1-channel preamp out
* dual-room/dual-source capability (stereo preamp output for second room)
* component video switching: 2 in, 1 out (50MHz bandwidth)
* digital inputs: 4 optical (including 1 front-panel), 1 coaxial
* optical digital output
* 4 audio (including phono) and 5 A/V (including 1 front-panel and 4 S-video) inputs
* on-screen display (requires TV with direct video input)
* learning/multibrand remote with macros
* OP Processing
* wide-range frequency response
* stereo and multichannel analog direct modes
* digital and video power management
* aluminum front panel
* cast aluminum heat sink
* oversized transformers
* Control A1II
* 2 sets main speaker outs
* 16-15/16"W x 6-5/16"H x 16-5/16"D
* warranty: 5 yearsCrutchfield also has posted pictures of the 'DA2ES. It looks like a DB receiver (i.e., 'DB1070) with the ES badge. Here is a link to the 'DA2ES at crutchfield.com:
http://www.crutchfield.com/cgi-bin/S...TRDA2E&o=m&a=0
