Sites for cover art, including back cover? (1 Viewer)
Gary Cliff
A couple of months ago, I came upon a site that had these types of graphics, but I didn't bookmark it. And now, I can't find it again. Do any of you know of any such sites? Thanks!
Deepak Shenoy
Gary,
DVD Empire (www.dvdempire.com) has both front and back graphics. They are usually prompt in putting up covers for new releases. However, these are not high resolution images that you can print DVD covers from. Hope this helps.
Voon Jiet
Voon
Try www.dvdexpress.com They have cover scans as well, although I doubt you can print them out for use as DVD covers.
So far, the best scans I come across are at www.horrordvds.com Only horror DVDs there (as the name suggests) but if ever needs scans of horror titles, that should be the first place to look.
Hope this helps :)
papill6n
