Anyone know of a listing for service menu codes for Runco projectors? I want to change the bulb in mine but need to get into the service menu to reset the bulb hours.
If you don't mind another question: I'm thinking of getting one of the ISF guys to calibrate the projector. (I wouldn't think of trying it, even if I had the right equipment, which I don't). In your experience, do DLP projectors benefit from this or are the factory temperature settings about as good as it gets?
I worked on a VX 5000ci over the weekend projecting onto a 183" screen. The factory grayscale at the "65" setting was considerably off. Very red/green.
It was fairly easy to calibrate it to track D6500 though and that did make a difference.
The projector was not meant to go this large of an image. There was very low light output.
Reds looked so different on this set than the typical orange reds I am used to seeing. The reds were ... RED!!
Great! I'll be on the phone to my local, friendly ISF guy tomorrow morning. I am really happy with the current picture, but, at the end of the day, aren't we all striving for perfection?
