RobertMc
- Jun 2, 2004
I have jsut purchased a Set Top Box that has a couple of connection options for setting it up. The unit is a TEAC DVB-420 (Australia model) that is only Standard Definition.
It has an SCART plug on the rear as well as composite video and LR audio out. There is also optical audio out as well.
My question is regarding what connection is going to give me the best picture quality to my 56" RPTV.
I currently have it set up directly to the TV and not through the A/V Receiver. I did try to put the composite audio/video through the receiver, but the connection from the AV Receiver to the RPTV is by component cable only, and the AV Receiver does not have video upconversion (Yamaha RX-V640). I presume this is why there was no image on the screen when I tried it.
So, should I be looking to get an SCART to Component video cable to run the box to the AV Receiver and use the optical connection for audio?
Or should I just run an SCART to SCART cable from the box to the TV and bypass the AV Receiver all together? Is one going to give me a better picture signal over the other.
Any hints and tips would be fantastic.
Rob
Rob
