Sat Picture issues (1 Viewer)
Kevin T.
Grip
IM noticing on some of my sat stations the picture is awefully pixelated, usually on most of the major stations, nbc, cbs, abc. Is this a common problem with the dish not getting a strong enough signal?, right now i think my signals are at 84 for sat 110, and 78 on sat 119. Not sure if this is normal or just me, getting used to my bigger TV
Kevin
Robert_J
Mississippi
With digital satellites, signal strength does nothing for picture quality. You either get a picture or you don't. A higher signal strength just helps combat rain fade.
Since you are receiving signals from 110 and 119, you are a Dish customer. On Jan. 1, to comply with the "must carry" law, Dish added around 300 local channels while not increasing bandwidth. To handle these channels, they really cranked up the compression. Lately, they have been tweaking the compression but from what I've been reading, they aren't even close to being back to "normal". On the other side, DirecTV complied with the same law by launching a spot-beam satellite to handle all of their local channels. (Dish's spot-beam sat should be launched soon)
Also, with a bigger TV you will see compression artifacts. Calibrate the TV with Avia or VE so the artificial contrast is turned way down. Other than that just get used to it.
-Robert
Marv74BR
