Tony TerBorg
- Jun 26, 2018
- Tony TerBorg
I recently purchased the XBR 75X900E and love the picture but am having a few issues with sound and communication when integrating it with my STR-DN840 receiver. System at this point is really simple. Samsung Blu-Ray player hooked via HDMI to receiver. HDMI out of receiver to HDMI input on display (I've used all four inputs), optical out from display to SAT/TV input on receiver.
1. When I use my Blu-Ray player, I get great 5:1 sound and picture but when I go to adjust volume, it pauses the DVD player for a 2-4 seconds before it kicks back in. (FYI - With previous LG display, I did not have this issue)
2. When I use stream audio from my TV (Netflix, HBO, Hulu, etc) to the receiver, and then go to change the volume on the receiver, it changes the input on the TV to the HDMI port being fed out of the receiver. I then have to rest everything. Only way around this issue so far is to disconnect the HDMI cable from the TV input when streaming.
3. No matter what I try, I cannot seem to get 5:1 surround out of the TV. Specs indicate the optical will send 5:1 and I have tried several streaming signal sources that state 5:1 is being sent. I have also made sure TV is set to output 5:1.
Any thought on any of the above issues would be appreciated in helping work out the bugs in the setup.
Thanks. Tony
Thanks. Tony
