morasp
- Oct 14, 2016
- steve
I was wondering if anyone could suggest a region free Multi format (PAL, NTSC) Blu ray/DVD player. I found one by Sony that seems like it would work.
The Oppo players are great, but the company is no longer making them and they're even more expensive now than they were new.
Good info, but IMO when you're looking at the 93, 83, and 80, you're paying good money for old, used hardware that's more likely to have problems than something newer.
The 103 at the prices you mention is still $100-$200 more than an already modded Sony/LG/etc., and then you STILL need to buy the Blu-ray region-free mod for it at additional cost unless you get lucky and pick up an already modded one at those prices.
I'm not saying that Oppo isn't a possible option, but really, if all you're looking for is a relatively inexpensive way to add region free Blu-ray playback to your system, they're probably not the best choice at this point in time.
The PQ on my Sony is just dandy, and for the relatively little use it sees the player is perfectly fine for the job, which is to play the occasional region-locked disc here and there. Just my two cents.
A 103 was especially good choice when the plug in region free mod was $50, but a bit less desirable now that module seems to be a minimum of 120-150 if you can even find it anymore. I have a 93 and 103D now.
I'm not entirely sure going for the Panasonic UHD or top shelf Sony and keeping a region free BD separate isn't the best choice right now
EDIT -- just looked at Ebay laughing at "Brand New 205 Buy it Now $6000"
I bought my Sony BDP-S1100 region free player from Amazon a few years ago and it plays everything from all regions. No issues and nice picture with both dvd & Blu-ray
I got the same one but from 220 Electronics. I've only had mine about 6 weeks. It's done everything right except it kept freezing towards the end of Spartacus 4K a few days ago.
You were watching the Blu-ray disc, correct? The BDP-S1100 is not a 4K UHD player.
I was going to ask about that. I do not have a 4K player or TV, and my understanding is that the Sony player in question upscales Blu-rays for 4K TVs but that it will not play a 4K Blu-ray. Is that correct?
Also, does the BDP-S1100 play SACDs?
Like the other folks have said the Sony BDP-S1100 does not play 4k discs. Does a nice job on dvd's & Blu-rays. I was told when i bought the player not to have a firmware update because it will erase the all region setting.I got the same one but from 220 Electronics. I've only had mine about 6 weeks. It's done everything right except it kept freezing towards the end of Spartacus 4K a few days ago. It must need new Firmware but I have the latest. I had to finish the show with one of my Panasonic players. I really like how the 1100 switches Wee-juns using the colored buttons. It's the easiest switching I've seen on an emancipated player. I'm pleased with the Sony all in all. It's played several Wee-jun B BD's flawlessly and that's what I bought it for.
The O.P. should consider the 1100.
I have my model numbers scrambled and so does Sony. Mine is a UBS-X1100ES. It does UHD-BD. Sony gets stuck on loving certain numbers that I presume they deem lucky, appealing, or something else too....??? Having multiple 1100 models is confusing. Sony loves 9000. They're always looking for a new unit so cool that they can bring back 9000, one, more, time.....until next time!
I guess Panasonic figured that out and beat Sony to the punch with the DP-UB9000.
I have the Panasonic DMP-UB900 for my 4K discs and it plays them with no issues.
