nolesrule
Jack, you should use #2, because the numbers on the volume dial are meaningless for calibration. For example, on my pioneer receiver, the numbers go from -90+ to 0. To get my front speaker at 75dB using the test tone, the volume dial would be at -27. If I set it to 0 on my machine, I'll blow my ears out among other things. If it were set up in a different room, it might be some number other than -27.
Then, I adjust every speaker to 75dB using test tones. At that point, I know that when my receiver is set to -27, the peak output will be 105dB.
That said, I usually listen in the -38 range or else I get complaints from my neighbors (I live in an apartment...for only 20 more days!!!!)
