Peter Apruzzese
- Dec 20, 1999
- Peter Apruzzese
If you’re unwilling to change the player’s settings as mentioned above, then yes, you’ll be limited to only one good sweet spot. You might experiment with your speaker placement as you shouldn’t be getting severe combing effects. When I was using a two channel system I was able to get a nice wide sweet spot after careful setup.
