bit_boy
Grip
- May 22, 2007
- Adam
Is it worth the trouble? I asked similar questions in my other post in Speakers & Subwoofers. I apologize for any possible cross-posting.
Here's what I've got so far. Sapphire SAT1500 speakers for surrounds, HSU STF-2 sub, Denon AVR-1604, Sony 32" TV, Sony 5 disc DVD/CD, & Dish Sat (not HD). The room is large (3800 cu. ft.) and odd shaped with all rooms connected to it. I have the couch near the back wall, and two large chairs on either side of the couch. The entertainment center is directly across from the couch.
I'm limited on where I can mount the rear surrounds due to a large window on the left side of the couch. Also, there is a bar with a large opening at the sink between the kitchen and living room. It looks like I'll have to mount the speakers in the corners of the room. If I mount them on the first available wall space ahead of the bar and opposite window, then the speakers will be well in front of the seating area.
Should I invest in the Radio Shack SPL meter and Avia DVD? It seems that everyone talks about it like it is the greatest thing since digital sound. Are these tools really that helpful (especially in a situation like mine)? I'm wondering if it will really make a difference or not if I am unable to move the speakers around. Or, maybe I misunderstand how these tools work?
My receiver has various settings for the sound delay from each speaker. It also has inputs for the distance to each speaker. It has the typical test tone stuff like most AV receivers. Will this be enough to set up my system? Can someone help me figure this out? I thought I was confused about what sub and speakers to buy. This is really stressing me out!
