Luitz
- Jan 4, 2004
I own a BGW 750c proamp which uses a 120mm x 120mm 110 volt fan to cool. I would like to know what fan your current proamp or amp uses for a fan (size and power) and if you at all find them noisey????. Generally 110v 120mm fans generate 46 ish db IMO way to loud for quiet passages in HT movies when the amp is in the same room.I'm pretty sure the new pro amps use a 12 volt fan half the cfm and half the db of mine which should be perfect for home use. I mean we dont run are proamps like there designed to be run all day long in a closest or stage for hrs and hrs at a time.
Also if You know of a 110v 120mm fan that produces less then 30db please tell me. Otherwise Im doing a 12volt mod to it as soon as i find out what other amps use by using a 12 volt adapter and a vantec stealth fan 120mm 26db
Please respond if yer reading this
Thanks all....
Thanks all....
