tom dettling
- Aug 7, 2003
I have decided so far to pre-wire for a front projector using (1)DVI-D, (1)Composite(5BNC's), (1)S-video and extra rg-6(f)connector. Should I add or take away from this list because their is no upgrading later. (unless i want to spend a ton of money to rip up the living room)
Second question is i want to terminate the wire at the wall and have extra in the ceiling to be used for a pole mounted ceiling projector. Their are a few companies that will fabricate the face plate and put the amount of feet of wire you need. I have talked to only one home theater store and he was against this idea. His reasoning of keeping to the least contact points sounded good to me but i want a second opinion. To terminate or not to terminate at the wall that is the question. As i am writing this why can't i terminate at the ceiling also.
Thanks for reading this.
