Possible issue with my Hewlett-Packard laptop (1 Viewer)
Jeffrey D
Jeffrey D Hanawalt
I bought this back in 2016, for the specific purpose of turning my CD collection into mp3 files for my car. I haven’t turned this on in quite a long time. I tried to fire it up this morning, and it’s been sitting for an hour with nothing but a blue screen- I can’t get the home page up. Is this laptop dead? Appreciate any feedback.
John Dirk
ATL
JOHN
Is it a blank blue screen or something similar to this? The best option you have is to simply restart it. If it continues to do the same thing, you'll probably need bootable media to attempt an OS reinstallation. Many PC's now have a recovery partition included for this purpose. You can check by restarting the machine and pressing the BIOS shortcut key [usually, F1, or DEL but could be F2, F10 or F12] during startup. If you're able to get into BIOS, look for a boot sub-menu and a recovery partition option.
If none of the above yields acceptable results then, sadly, you're probably better off replacing it as laptops are generally not worth repairing, cost-wise.
BobO'Link
Mid-South
Howie
And if you're getting that "We're collecting some error info" screen you do *not* need to wait for it to finish (which can take a very long time) - just reboot it and try again. It may take 2-4 boot attempts before you're presented with the Windows recovery screen. It will provide options ranging from attempting to restore from the last backup/system restore point, to performing a clean install. It looks something like this (may be different depending on OS version):
Select Troubleshoot to get this screen:
Try "Startup Repair" first - then possibly "Uninstall Updates" if you think an update caused the issue. Finally just try a "System Restore" to wipe it and start over. IIRC it'll have 2 options - one that keeps existing stuff and another that blows it away.
Jeffrey D
Jeffrey D Hanawalt
It’s a blank blue screen, so far. Will try to power it up again, when I get home in a little while.
Thanks to all for the feedback.
I can’t get anything to come up, other than a solid blue screen. Looks like it’s dead. Unfortunately, it looks like I may not be able to get another laptop that has a built-in CD drive. 🙁
John Dirk
ATL
JOHN
Do you have a bootable Windows disc? If so [and you haven't already] give that a try.
True but you can buy an external drive that connects via USB for under $50.00.
Jeffrey D
Jeffrey D Hanawalt
Thanks for these suggestions. I think I’ll take a road trip to Staples today. Is this Windows bootable disc something I can find there?
John Dirk
ATL
JOHN
Unless you need it right now, you'll probably do better ordering an optical drive from Amazon.
Unfortunately, no. They have to be created using procedures outlined by Microsoft and require a product key, a sort of digital proof of purchase. Look for a label similar to this one on the laptop.
Jeffrey D
Jeffrey D Hanawalt
I just browsed at Staples, and they didn’t have any external CD drives there.
Bob Gu
Bob Gudera
Don't give up on shutting it on and off. Try disconnecting the power cord and depressing the power button for 10 or 30 seconds. Wait awhile. Then plug it in again and press the power button on.
Or try shutting off again and press the power button on immediately.
I lost the sound on my HP. Everything said it was working. Holding the power button down until it shut off and restarting brought the sound back.
BobO'Link
Mid-South
Howie
If reinstalling Win10/11 on the same system you shouldn't need a product key as that'll be stored in your online profile both "require" to do the installation/initial setup. Once installed you can switch to a local account but that info is still in MS's cloud. Most (all?) systems (laptops especially) purchased in the last 5 or so years no longer have that product key label as it's usually imbeded in the BIOS. BUT you can *still* use a Win7 product key to activate Win10. If your laptop *does* have such a label it'll likely be in the battery compartment of a system with a removable battery.
You can use the instructions from MS to create a bootable USB drive for installation instead of a disc. If you have a USB-SATA cable you can also use an old SATA drive as the USB drive for media creation.
Malcolm R
Malcolm
Stores may vary, I guess. :( I saw them in two local stores around here when I was shopping for a new desktop for family at the end of July and thought they might need an external drive as they've saved lots of things to CD's over the years and most new computers don't have them built-in. I think they were in the aisle with portable storage items like USB stick drives and SD cards. I recall they weren't actually near the computers in my stores.
Jeffrey D
Jeffrey D Hanawalt
Very good news. Not to state the obvious but you need to do a complete backup and create recovery media immediately. It's probably just a matter of time before the problem returns.
The message on the screen was the battery had no juice, so I assume it took a while for the external power to wake up the battery.
Scott Merryfield
Mich. & S. Carolina
Scott Merryfield
Even so, I would take John's advice and create recovery media. Also, you probably should make a habit of plugging in the laptop, booting it up on occasion, and applying Windows updates. I have a laptop that only gets used when we travel or we have a Zoom call, and I try to do this on a monthly basis. I will update the few applications that I use on it, as well.
BobO'Link
Mid-South
Howie
Yeah... keep it charged. If it has a replaceable battery maybe look into purchasing a replacement since it took so long for it to charge.
Nielmb
