MikaelG
- May 20, 2002
I've recently purchased a Marantz SR-4300 and I have a problem with it. I'm in Europe, so I have the 230 V / 50 Hz version.
It hums and buzzes out of it constantly, and pretty loud. I have connected it to several different speakers with different speaker cables, in different rooms, but that noise is still there. There is no way to listen to anything, cause it sounds like a 20 dollar old stereo amp.
The problem is not in any of the inputs, because I've connected it both to a source (both A and D) and two speakers, AND just connected it to one speaker, with no other cables, and it makes no difference.
When I hit the Mute button, or set the volume to 0, that is -72 dB, the noise is significantly reduced, however it's still there, and as soon as I just raise the volume to -71 dB, the noise gets about 10 times louder. The "noise volume" is pretty linear from -71 dB to about - 15 dB, from there it increases the more I turn on the volume wheel.
The buzz comes from the treble driver, (PPPPPPPPSSSSSSSSSSSSSSSSS) and the hum comes from the bass driver. The hum sound, sounds exactly like when you've unplugged the cable from a guitar, connected to an amplifier (BRRRRROOOOOAAAAAMMMM)
The hum and buzz is also present when I've connected active speakers to the 6.1 pre out, for ex a subwoofer, it hums like crazy from it, it's unbearable.
The most strange part of all this, is that I've of course reported this to my retailer, and I've got a new one sent to me, but this sucker has the exact same problem. I don't understand, what the h-ll is wrong? :frowning:
I haven't checked with my neighbour yet if the hum appears in his appartment too, but I will. I have a bad feeling that it won't make any difference...
In all rooms that I've connected the amp, I've always connected it directly to the socket, with nothing else connected in the entire room (even the TV antenna).
I had a Denon AVR-1602 before and there was no such problem, eventhough everything was connected identically.
Any gurus who have experience with this problem that can help?
Thanx in advance
Thanx in advance
