Maza
- Nov 2, 1999
Hi, I am setting up my home theater with the following speakers and would like your input on setting it up correctly:
Front: Paradigm Monitor 11
Center: CC 370
Surr: ADP 370
Sub: PW 2200
My receiver is a NAD T-752, which has a variable crossover to accomodate different speaker setups. My question is where should I set the crossover, the available frequencies are 40, 60, 80, 100, 120, 140. This applies to all speakers set to small.
The specifications on the Paradigm Monitor series state two different frequencies, which I don't understand, one says "Low Frequency Extension", which for the front is 35hz, center 57Hz, surrounds 55Hz. But then there is also a specification named "Frequency response: On Axis", which states 48hz -20khz for the front, center is 100 Hz - 20 kHz, and surround is 70 Hz - 20 kHz.
Ideally, I would think that it is better to get as much bass as the capabilities of the speakers specify, so my guess is that 80Hz crossover should work the best, altough if I apply the "Low Frequency Extension" specification maybe 60 Hz could give better results.
I understand that the ultimate decision should be based on listening, but was wandering what should work best in theory.
I appreciate your help,
Marcos
Center: CC 370
Surr: ADP 370
Sub: PW 2200
Marcos
