Mike Up
- Dec 16, 2002
I had an issue with sensitivity being very low while using the Right input labeled LFE. I found that if I put LFE to NO and used both Left and Right, I gained 6db in output. I then found that the Left input was enabled with LFE setting to YES. I checked with a subwoofer noise output and LFE = YES, the crossover knob had no effect. Changing to LFE = No, the crossover knob did have effect, filtering all higher bass out when set at it's lowest value.
So then I found that if LFE = YES, and using both Left and Right input, I gained 6db and had the sensitivity of other subwoofers. Both Left and Right line level inputs were not filtered with LFE = Yes and both Right and Left line level inputs were filtered with LFE = NO.
So I'm finding that the instructions are wrong and you should use both left and right inputs with an LFE subwoofer output, split with a Y cable and 'not' use only a single connection to the Right/LFE input for "BEST" results of less noise induced into the open input and higher sensitivity. Manual says to only use a single subwoofer output to the Right/LFE line level input which creates less sensitivity and the potential for more noise.
What have you other Polk DSW Pro subwoofer owners found, especially the Pro 660wi owners.
Thanks!!
Thanks!!
