spk1973
- Nov 16, 2010
- Shawn
Hi,
I've got a pair of Cambridge Soundworks Great Outdoors 52 Speakers, had them for a few years, last fall when I brought the speakers in I tucked the cable ends under the edge joist of the deck where the speakers are hung, it kept the precipitation from falling directly on the alligator clips, but this spring when I went to install the speakers the wire at the connectors was corroded and needed to be cut so I could re-attach the connectors. I don't want this to happen again this year. Any advice as to how to seal the connector ends of the wire for the winter to keep out moisture/elements? This may be a simple question but I'm looking for advice on a tried-and-true method. Any help much appreciated.
