Onix Rocket RSC100 Center Channel @ $160 (1 Viewer)
tyrro
Onix Rocket RSC100 Center Channel Speaker (South American Rosewood Finish). Retails @ $349. Yours for just $150!
The speaker is just three months old and in almost brand new condition with a small blem or two. Still has original double boxing for shipping. All info and specs are from AV123.
The RSC100 may not be as big or as pricey as the whopping RSC200, but it's not likely to get an inferiority complex anytime soon. Listen to the RSC100 for yourself and you'll see why we think it is bound to be our most popular center channel.
If you were to examine the individual sound channels in a typical Dolby Digital or DTS movie soundtrack, you'd find that the center channel carries more than it's share of the load. It's responsible for projecting crystal-clear dialog, compelling background music, and startling front sound effects. That's why audio experts agree that the center channel is the most important loudspeaker in your home theater. With that in mind, we developed the magnetically-shielded RSC100, an aggressively-priced two-way, three-driver center channel comprised of our custom 1" aluminum-silk hybrid tweeter and two 5.25" aluminum alloy woofers (just like those found on our top-of-the-line RS750 tower). In addition, the RSC100 has been carefully voiced to timbre match the other speakers in the Rocket line, and works especially well in conjunction with a pair of RS150s as rear surrounds or a pair of RSS300s at the sides.
Features:
  • 2-way System
  • Rear vented enclosure
  • Custom 1" aluminum dome tweeter, two custom 5.25" long-throw aluminum cone woofers
  • 60 Hz to 20 KHz (± 3 dB)
  • 8" H x 8.5" D x 20.25" W
  • 25 lbs each
Specifications:
  • System: Two way, three driver direct-radiating system, vented enclosure with rear-firing flared port
  • Drivers: Custom 1" aluminum dome tweeter, two custom 5.25" long-throw aluminum cone woofers
  • Crossover: 3.8 kHz, 3rd-order alignment
  • Frequency Response: 60 Hz to 20 KHz (± 3 dB)
  • Impedance: 4 Ohms nominal
  • Efficiency: 92 dB (@ 1 watt / 1 meter)
  • Dimensions: 8" H x 8.5" D x 20.25" W (203 x 216 x 514 mm)
  • Weight: 25 lbs (11.3 kg); ship weight = 33 lbs
annefnlys01
