Noise-Cancelling Headphones (1 Viewer)
Nevin
Hi, I was wondering just how much noise noise-cancelling headphones can block out. I was thinking of buying a pair for when I'm mowing the lawn (which is much too large). Do you think a pair of these would block out most of the engine sound from a noisy riding mower? If so, are there any models that you could recommend for under $100? Thanks in advance.
P.S. Sorry if this is in the wrong forum. I didn't know where to put it.
Bob McElfresh
This is probably more of a "Tweeking" post, but no problem.
Because of the comfort/weight, you would be better off using shooting muffs or the foam ear-plugs sold at the drug store.
The noise-canceling headphones are not usually designed for really-loud equipment noises. The are more designed to filter out airplane engine noises on long trips, or office noise. They are also desgined to plug into a portable CD player/radio which would up the price if you dont already have one.
I did buy the $300 Bose headphones for a daughter taking long plane trips. For office use, a co-worker thought they did an ok job (he sat near some people who used the phone a lot). But a day or so later he returned them because he kept being startled by people walking into his cubicle.
Greg_R
Portland, OR
Greg
Check out the in-ear style headphones by Etymotic. You might be able to find the ER-6s for ~$100. These block 20dB+ of noise and have excellent SQ as well...
foster2292
